How fast are ZTRs Really?
   / How fast are ZTRs Really? #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I have read some of the brochures on some of the zero turn radius mowers with 60" decks that claim 7 to 10 acres per hour mowing time. I know these things are more maneuverable, but the thing would have to be going too fast to cut with any kind of quality to achieve this kind of mowing speed. Plus, the dern thing would buck you off in the process. With my 60" finish mower I'm lucky to do 1.5 acres an hour.
What is the real story on this?
   / How fast are ZTRs Really? #2
The ones claiming 7-10 can do it in ideal conditions but they are extremly fast and deliver an exceptional cut while doing it. I was talking to my local dealer for Grasshopper and he also sells Valtra tractors and he demonstrated how well the grasshopper cuts while cutting 3' high hay. The machine never even bogged down and left an impressive cut at a high speed thru that rough of an area. If I were you I would find a dealer and give one a try. You save a lot of time on turning compared to traditional mowers. I wouldn't trade your machine in or nothing but just trying one lets you understand how they work so well.
   / How fast are ZTRs Really? #3
To cut 10 acres per hour with a 60" mower deck would require a ground speed of about 15 mph and 100% efficiency. For most of us, a ground speed of 5 mph is reasonable and 80% efficiency is about max, and this results in a cutting rate of about 2.5 acres per hour.
   / How fast are ZTRs Really? #4
Alan,
I have a 1996 Exmark Turf Ranger. It has a 60" deck and a top ground speed of 6.4MPH (slower than most). The cut does not degrade while going at top-speed (except in really thick and tall grass).
At 80% efficiency, my mower will do approximately 3 acres
per hour.
see <A target="_blank" HREF=http://www.exmark.com/productivity.htm>http://www.exmark.com/productivity.htm</A>
   / How fast are ZTRs Really? #5
I have a Gravely Promaster 260Z, 25hp, 60 inch cut. I cut a 2.5 acre lot in about 50 minutes. Used to take me about three hours on a riding mower. Two things contribute to the speed increase. Speed, and manuverability. ZTR'S achieve good finished results at high speed because their blades are spinning at higher speeds than most other machines. Sometimes as much as twice as fast if you compare my Gravely to my old Yardman riding mower.
Jerry
   / How fast are ZTRs Really? #6
My new house has about 2.5 acres of grass to mow. The first time I did it with my LX 279 with a 48" deck and it took me three and a half hours to do it. The dealer brought out a Landpride ZTR with a 60" cut and I easily mowed it all in an hour and it looked very good. I thought very seriously about it but the $9k price tag was too much for me to justify for a lawnmower. I am using my 6' finish mower and 4600 to mow the big areas and then the 279 to do the smaller spots. It takes me about the same amount of time.
   / How fast are ZTRs Really? #7
Many of the commercial turf mowers on the Lawn Forums site say they are mowing at 10 to 12 mph mostly with the Dixie Choppers and getting exceptional results.
Our Toro Fairway mowers on thegolf course mow at 7 to 8 mph but everything there is relatively smooth.
Bill
UNUSED LANDHONOR CONCRETE POST DRIVER (A50460)
UNUSED LANDHONOR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
KUBOTA L39 BACKHOE (A50458)
KUBOTA L39 BACKHOE...
JCB 8085 EXCAVATOR (A50458)
JCB 8085 EXCAVATOR...
UNUSED LANDHONOR SKID STEER BALE SPEARS (A50460)
UNUSED LANDHONOR...
UNUSED LANDHONOR SKID STEER ROOT RAKE (A50460)
UNUSED LANDHONOR...
