newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 13,974
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
In http://www.tractorbynet.com/forums/projects/334565-another-shed-question-screws-nails.html?highlight= I had about decided to use screws for a shed build which is about 180 feet from power.
However later review of other info indicated that nails should be used for things which experience shear, but screws are good for things under load, like putting deck boards down.
In another thread I asked for help picking a framing nailer.
http://www.tractorbynet.com/forums/projects/334486-type-then-brand-framing-nailer.html?highlight=
Based on the excellent advice rec'd here I'm probably going to buy a Hitachi Model #: NR83A3S.
Now I've already got an air compressor (Makita MAC2400, 4.2 SCFM @ 90PSI ) and a 8K generator (http://www.tractorbynet.com/forums/welding/336996-smokin-deal-10-000watt-generator.html) (thanks Sodo).
The compressor draws about 13 amps. I've 20 amp 120V circuits. I'm thinking of trying to string 100' of 12 gauge extension cord then running 100' of 3/8" air hose. This way I could leave the compressor in a fenced area and not have to cart the generator back and forth in my FEL. Does this sound feasible? I only plan on running the nailer for about 12 nails, then there will be setup time for the next 12 nails. I know the nailer "requires" more CFM, and I'm looking for a more powerful compressor but as always $$ are tight.
I'm not sure about the friction loss in air hose.
I've also got 50' of 10 gauge extension cord, and could easily get more air hose.
Comments? Suggestions?
