How does this work with remotes?
   / How does this work with remotes? #1
rprecision
Colorado
Farmpro 2430
So I let's say I buy, rent, borrow a implement for my L6060 which has been used on another tractor.
If I hook up and run it I will exchange whatever hydraulic fluid that's in the cylinders which is introduced into my system.
Since the hydraulics and transmission all utilize the same fluid what is the risk of contaminating my system causing potential damage to the entire system?
I know these systems are pretty sensitive to the incorrect fluid.
What say you?
   / How does this work with remotes? #2
Sensitive to the incorrect fluid? I wouldn't say that.
Kubota SUDTII may be superior to TSC Traveller brand, but both work without damage.
Mostly a non-issue, IMO.
   / How does this work with remotes? #3
Your tractor is sleeping with any tractor that impliment has slept with... A quart or 2 of cheap hydraulic fluid is unlikely to dilute your nice SUDT2 significantly. But I worry about contaminated fluid (mostly metal, but could be other dirt & grit). The hydraulic filter is on the return line, not the suction (cavitation from a slightly plugged filter will do more damage to a gear pump than some contamination) so would in theory filter out most contaminants before they got to your sump. To be safe you could remove the QD off the other hose & extend/retract the cylinder or spin the motor until your fresh fluid pushed the mystery fluid out. Dumping some John Deere red hydraulic dye in your sump makes that easier (not to mention easier reading sight glasses or dipsticks).
Personally I drained the cylinder (in addition to other maintnance) on my new to me 3pt trencher before I started using it. I've thought hard about this subject relating to the local extension offices rental no till drill. Haven't ended up renting it, mostly for other reasons, but would likely "waste" a gallon of good SUDT2 purging it before risking contaminating my HST+ tranny.
   / How does this work with remotes? #4
Good response.
   / How does this work with remotes? #5
You could spring for a remote cylinder and hoses for your tractor. Then when renting/borrowing, have them take their cylinder off and you install yours. It's like practicing safe coupling for your tractor.
If you end up with an implement that needs a remote cyclinder, you are set.
Ron
   / How does this work with remotes? #6
We use our new to us grain drill(requires a cylinder) on three different tractors,Case,John Deere and Kubota;I own the Kubota and purchased my own cylinder and hoses/connectors are different also.
   / How does this work with remotes? #7
Ron
The only issue with this is that cylinder probably will only fit that one impliment. Fine if you borrow/rent that impliment a bit. But overkill for one use.
I think you are worried about the same potential STD problem I am.............. I appreciate the input!
Thanks for all the replies, I think the bottom line is one should be cautious but not paranoid. Best to pick a good clean implement partner first...........
   / How does this work with remotes? #9
ThevThings people worry about is baffling. You should be more worried about how the old borrow equipment looks hooked up to your shiny tractor . What in the world will the neighbors think. LOL
   / How does this work with remotes? #10
Problem I have found with lines and cylinders on used equipment I have bought is water in the fluid. I check and drain if necessary. Otherwise we switch implements between tractors often and never have had a problem we considered fluid related.
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
FRONTIER WR3212 LOT NUMBER 57 (A53084)
FRONTIER WR3212...
