How does the Disc Edger work?
   / How does the Disc Edger work? #1
smartguyz
Beaverton, Oregon
JD318, Power-Trac PT425 with scuffed-up green paint.
Hi guys -
Does anyone have the disc edger for the 422 or 425? How does that thing work? The picture doesn't make it clear. Does it have a spinning blade? How it it controlled? Does it have a little hydraulic motor on it? Does it edge/trench OK? The photo seems to imply that it can't be moved around much on the end on the boom. I'm very curious. Thanks!
-Rob
   / How does the Disc Edger work? #2
Hey Rob - I had one - but traded it back in when I purchased some other PT stuff - it is OK for rough cut out work - but for fine bed edging I don't recommend it - I didn't like it much because it was very difficult to control / get a straight line - and virtually impossible to follow curved bed contours exactly - I would have been long finished with a powered one. Hand powered edgers do a far superior job for me - It does not work at all for trenching - I ended up buying a fairly decent powered edger for around $400 - it does the job - not as well as some more expensive ones - but I use it every few weeks primarily to keep a nice clean edge on all my beds (probably around 500 ft worth)
The Company - Bedshapers - makes a really nice one that will also do small trench work and create a very nice inside profile for the bed - it also has really nice steering control but I think that unit is around $1,500
The PT unit does not have a hydraulic motor - it just uses downpressure and the speed of the tractor on the disc to cut (the disc is not real heavy either) so it does not cut the grass that well.
Well thats my experience - I liked the idea originally but it didn't work out - Hope that helps - not sure if anyone else has one on here.
   / How does the Disc Edger work? #3
I don't have one and didn't get one primarily because of the reasons that Ed listed. The blade doesn't spin.
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
378550 (A51573)
378550 (A51573)
378584 (A51573)
378584 (A51573)
2016 JOHN DEERE 3032E LOT NUMBER 97 (A53084)
2016 JOHN DEERE...
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
