How does JD "unsynchronized sliding gear" compare to Yanmar Powershift?
   / How does JD "unsynchronized sliding gear" compare to Yanmar Powershift? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
Pretty much said in the title... How does JD "unsynchronized sliding gear" compare to Yanmar Powershift?
   / How does JD "unsynchronized sliding gear" compare to Yanmar Powershift? #2
Like a standard shift verses automatic.
   / How does JD "unsynchronized sliding gear" compare to Yanmar Powershift? #3
Even worse than an automobile transmission that has usually has synchronizers to make gear engagement smooth.
I assume JD "unsynchronized sliding gear" is the same as the MT Yanmars. Assuming it is the same, it means a full stop before any gear change. (Or else horrible expensive-sounding grinding). It can't be shifted in motion. Or even standing, after the inertia of a mower etc gets the gears spinning.
Some people might say you can double clutch it but that assumes constant speed gliding along by inertia on asphalt, not lurching over native ground.
Powershift is vastly better. Just shove the gear lever into the intended gear and it takes care of the rest. Clutching is a good idea to ease stresses but it isn't essential.
   / How does JD "unsynchronized sliding gear" compare to Yanmar Powershift? #4
:thumbsup: Powershift is very smooth and effortless almost like shifting from low to high on a car.
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
