jcmseven
Veteran Member
Fellow Posters:
I have a question that came up for debate yesterday between myself and a friend. We discuss often about PTO hp and its affect on attachment performance, but what about hp and ground engaging performance. Does a tractor that has more horsepower and torque have more "pulling power" with a box blade, rear blade, loader, etc (pushing there) than one with less? Since I am a John Deere owner I will illustrate with that brand but any brand owner can chime in. For example: a 3320 John Deere (32.5 hp; 25.5 PTO hp and 62 lb-ft/torque, non-turbo) v. a 3720 JD (44 hp; 35.5 PTO hp and 84 lb.ft torque (rated)); would they pull a box blade the same, or one better because it has more power. They weigh the same; they can both be ordered with hydro trannies and similar tires. Assuming that each is similarly ballasted, which would do better? Would a gear drive (sync) make either one do better? This question came about because one of my work colleagues is looking at a new tractor (the two mentioned). Because the 3720 is more expensive he thought the 3320 would be better, but he is strictly using the machine for grading and loader work. It likely will never see a PTO attachment; should he spend the extra money on the more expensive machine, or would they be equivalent in this case?
John M
John M
