How do you wire 6 volt voltage regulator to a 6 volt generator?
   / How do you wire 6 volt voltage regulator to a 6 volt generator? #1
John Deere Tractor
Rio, WI
1949 John Deere
I am putting my 1949 John Deere B tractor together and I can not figure this part out? Any help?
   / How do you wire 6 volt voltage regulator to a 6 volt generator? #2
it's pretty easy.. the reg set's right on the genny. field to field, arm to arm, and that's about it. if your reg is using a seperate ground strap, make sur eit is grounded with the genny case.
last wire left is battery.. that heads out to your ammter net charge / discharge setup..
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
2015 International ProStar Truck, VIN # 3HSDJSNRXFN563873 (A51572)
2015 International...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
2007 PETERBILT 379 MID-ROOF SLEEPER (A52472)
2007 PETERBILT 379...
2018 LEDWELL LW48HT2-10 PB-LP (A52472)
2018 LEDWELL...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
