I think most plug torque specs now have to do with protecting aluminum heads eh? I have a few torque wrenches but rarely use em, I've broken enough bolts now I have a good feel for where I should be! At least they've all been rusted bolts I'm trying to unscrew.
</font><font color="blue" class="small">( <font color="blue"> Tighten 'til it strips then back off 1/4 turn </font> /forums/images/graemlins/crazy.gif
Dennis, that is a GOOD one! Welcome to TBN, you're going to fit right in, I can tell. /forums/images/graemlins/laugh.gif
I've never measured the torque on any hydraulic line or coupler, just make it good and snug - well, halfway between snug and tight as he$$. I used to be "torque wrench happy" until I realized that MOST torque specs that you find in any manual are just based on a universal torque chart that relates torque to the diameter of the bolt/size of the nut. Once you have a "feel" for what those torque values are, you can work much faster. For example, I used to use a torque wrench on spark plugs, which are usually around 15 ft/lbs. Now is just go by feel - make sure the little metal gasket gets fully crushed, then add a hair more. Without a gasket, just make them good and snug.
Of course there are MANY fasteners that should (MUST?) be torqued with a torque wrench. Head bolts, crank pulleys, intake manifold bolts, main bearing caps, piston rod caps, stuff like that.
)</font>
