How Do You Replace A Water Pump?
   / How Do You Replace A Water Pump? #1
jimwhart
Bascom, Florida
MF 135
I have a 1976 MF 135 gas burner with a three-Cyliner Perkins Engine. What should I do to replace the water pump?
   / How Do You Replace A Water Pump? #2
I'm assuming it's leaking? I would first source a replacement pump so you can physically see what you are up against. It's usually not too bad of a job, mostly getting stuff out of the way so it can be removed. Careful with removing the fan blade-the radiator cores can be fragile!
   / How Do You Replace A Water Pump? #3
Don't know anything about the MF but many times it's easiest to just remove the radiator first - sometimes just two hoses and 4 bolts. Then everything is right in front of you and no access issues.
   / How Do You Replace A Water Pump? #4
Remove fanblades........loosen bottom radiatorhose..........loosen 4 mountingbolts and remove old pump.......clean timinggearcover..........mount waterpumpbackplate (backelite or stainlessteel)very importent ! Mount gasket and pump ........mount fanblades.......connect hose and fill with mix off water and anti-freeze !
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
43029 (A51691)
43029 (A51691)
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
