How do you plant a dock?
   / How do you plant a dock? #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
The other evening one of the guys asked how to sink poles into the bed of his pond so he could build a solid dock. He also would like to build an enclosed gazebo kinda thing at the end of it. Of course we had all sorts of good ways to do it, but the mountains are too far from the bay to have some bud who's a pile driver by day stop over and moonlight. He wasn't wild about draining the pond, and since he's not the original owner can't be blamed for not doing the construction BEFORE adding the water. We're stumped. Anyone have an idea how to do it?.................chim
   / How do you plant a dock? #2
<font color=blue>How do you plant a dock?</font color=blue>
Dock seed!
But seriously folks;
It probably depends on what type of bottom the pond has. Also, does the lake ever freeze in winter. If so, the dock has to be removable. Solid bottom, just some pads would do. They also make some cork screw looking devices that you can screw into the bottom. They are a few feet across. I don't have any idea how you screw them in. Soft bottoms are the hardest. Lots of people use floating docks in that situation.
   / How do you plant a dock? #3
I used some handy gadgets from my local hardware store.
The first component is approximately 10-12" in diameter with a square hole in the middle that a 4x4 post will fit through. You sharpen the end of the 4x4 and slide it through as far as you think you can sink it in the muck and then lock it in place with stainless screws.
The other component has two pieces. The first piece bolts to the side of the dock. The second piece is a U shaped clamp that bolts to this. You slide the post through this and tighten the bolts when you get it level.
I installed it last year. It has settled a couple of inches since then. I've been waiting for it to warm up enough to go swimming and re-adjust it. The biggest problem I had was due to my pond bottom being far rockier than I thought. I probably could have set the footers at the end of the post.
All of the parts are made from HD extruded aluminum. SS screws and bolts are included.
I believe they have a web site, but can't remember the name. If you are interested, I'll swing by the store.
-david
Thanks for the info so far. Anything additional would be welcome - I'll print it out for the guy.
Yes the pond does freeze. I don't know the exact location, but it's far enough North in PA to freeze in Winter..........chim
   / How do you plant a dock? #5
If the pond has a soft bottom. just take a water pump,intake into pond. On the outlet side neck down to 1", attach a 10' peice of pipe (depending on death of water). Then jet out a whole in the bottom @ 18" in diameter and @ 3 to 4 ft deep. Insert 12" sonatube (waxed cardboard tube concrete form), making sure its plumb backfill around bottom with 3/4minus crushed gravel. Cut off at level you want to fill to. Add concrete, and reinforceing steel. Your local batch plant can advise on proper mix to set up in water. Add J bolts or post anchors. Now you have ice impervious post for your dock or structure. Same excavation/backfill method can be used for steel or treated piling also.
Oh just remembered a second method. In which I saw someone vibrate 6" steel pipe into lake bottom. using a plate compactor. They had some sort of homemade mount to keep the PC on top. You would have to be very careful trying to maintain plumb using this method.
   / How do you plant a dock? #6
I wanted to use <A target="_blank" HREF=http://www.intechanchoring.com/>Helical Screws</A>, but couldn't find anyone to put them in over water. Check out "Walkway" section of this web site. These devices solve the "soft bottom" dilema, since you screw them in until you get enough resistance - this indicates you've hit stable footing.
   / How do you plant a dock? #7
Here's a link to several dock makers.
<A target="_blank" HREF=http://www.boating-directories.com/boat_dock_manufacturers/boat_dock_manufacturers.htm>click here</A>
   / How do you plant a dock? #8
Have you tried some of your local drilling companies or maybe some directional boring companies.
   / How do you plant a dock? #9
Extremely timely discussion! I have been working on the same problem. I have a few ideas (wild schemes?) to share but they aren't tested by me yet. Having been around docks a lot (lived on a sailboat for almost 9 years), both floating-teathered as well as floating with pilings and various variations I decided nothing I have seen to date is a good match for my desires regarding a tea room/gazebo out in the middle of one of my largest ponds. I too discarded the pile drive approach as too expensive. There are various approaches that appeal to me and depending on how soft and how deep the soft goes someone might like one of these ideas.
First, please note that you may pour concrete underwater with great success. In fact I have seen commercial jobs where the surface of the slab was flooded and kept under two inches of water for quite a period whilel it curred a while. I have seen boat ramps poured in sea water (salty) to the satistfaction of the resident officer in charge of construction (ROIC, an architect and PE) at SUBASE San Diego for the Coast Guard small craft at Ballast Point.
If you want a large footprint to distrubute the loading and slow the rate of any subsidence, build forms to be placed on the bottom of the pond with vertical risers of the diameter of the support columns you want. As a previous poster mentioned, sonotube could be used for that and some of the softest silty bottom could be removed before placing the forms. I am considering using large diameter plastic pipe instead of sonotube. I would split the pipe lengthwise and put it back together with hose clamps or similar and other fixtures as required. This form for a column would be attached to the essentially square form so that it would be free standing. the lower end of the vertical pipe/form must not protrude very far into the volume of the rectangular form.
Let me pause here to mention that I am open ocean SCUBA qualified and working in reduced visibililty of a pond with stirred up mud, allthough not really pleasant, is not an impossible task to accomplish by the "Braille" method. Still I would prefer minimum "bottom time" on this project.
Concrete can be poured down the vertical pipe and it will flow down the pipe into the form below, displacing the water in the form. It is my belief (fond hope) that I can use a length of, say, 1 inch PVC as a handle to a tamper with maybe a 6x6 inch flat on the end at rt angles to the run of the handle. With this tamper I hope to move concrete out from the central vertical pipe form to fill the entire form. When this fails, I go in with a garden rake and other implements of destruction with my hookah rig (to not have to carry a tank on my back) or a snorkel depending on depth and conditions. I am considering filling HD bags with concrete and using them to transport concrete to the rectangular form and pouring the crete into the form. This is a back up contingency if the tamper and or rake ideas crash. Another back up contingency is to use another PVC pipe (not split and put back together) as a chute to direct concrete into the area of the rectangular form not near the central split pipe/form. You don't have to go down with a trowel and finish the crete unless you are way more fastidious than I am.
Of course you put rebar in the rectangular form and bent rebar to connect the horizontal rebar to the vertical rebar in the vertical form. I recommend a pretty stiff mix and to mix it for at least 3500 or better yet 4000 PSI. I struggled with thoughts of placing steel attachment points in the vertical cast column but decided I would add attachments to hold structure after cure rather than complicate things. If I did want embedded bolts or something I would place them in holes drilled along the seam where the vertical form comes apart. Based on previous encounters with Murphy, I would probably find the bolts/attachment hardware to not quite end up where I want/need them but as I am a year away from this project I could decide later to take the time to figure dimensions closer. I still need to chat with an engineer who might give me some insight as to load bearing issues to help me decide how large to make the "feet" on the ends of the columns. Left to my own devices, I would just make them so big they would have to be big enough. The reason for the split PVC vertical form is so it can be reused over and over (sonotube usually can't be although it too can be split waterproofed and reused if not embedded in the "foot".
If I opt for a "big bang" job rather than a form a little pour a little process amenable to mixing small quantities of concrete in my 3PH mounted PTO driven concrete mixer, then I will probably use sonotube or waterproofed cardboard tubes gleaned from a roll products operation (carpet, linoleum, whatever) instead of reusable PVC forms and hire a concrete pumper and redi-mix truck. I can make floats to make hose handling easier and just pump the horizontalforms full by guess and by gosh then fill up the vertical forms. If someone tries this method, be careful regarding the mix. Pumpers are notorious for thining the mix to make it flow easily but adding too much water is a BAD idea. Establish in advance what slump they can pump and that it is satisfactory for your needs then hold their feet to the fire to get that slump. They will ruin an otherwise good job if not watched. This is not an oppinion based on one observation or just my experience.
All of the forgoing assumes that there is little or no strong currents flowing through the pond during this work. In strong current situations yo may have to put a lid on the horizontal forms with holes out toward the periphery.
I will be extremely pleased if anyone notices anything impractical about any of this as I would rather have a difficulty pointed out to me now than have a problem when several yds of crete are involved and a lot of forms are in place.
Patrick
   / How do you plant a dock? #10
Patrick I like your ideas, especially the spread footing. Just food for thought, if you considered just leaving the plastic pipe/form in place. You would have an attractive column when your finshed. Just fill your box form to top then push the plastic pipe/form on down to the bottom of the fresh pour, add your rebar with small right angles at the bottom. Fill to proper level, add optional anchor bolts, post brackets, etc. Then your ready for your structure.
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2004 Rome Plow TAW-16 S/A Towable Disk Harrow (A49346)
2004 Rome Plow...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2022 GMC Savana 16ft Box Truck (A48081)
2022 GMC Savana...
