How do you lube 3PT ball joints?
   / How do you lube 3PT ball joints? #1
MicroPilot
Veteran Member
Northern KY
Cub Cadet GT3500 hand-me-down
Like the topic says. Seems like if I smear grease on the "ball" it doesn't really get in where it really needs to be. Is there some other way to do this?
   / How do you lube 3PT ball joints? #2
I have dropped my lift arms all the way and put the ball ends into a coffee can of oil leaned over and let it soak a while. Do the same with top link, just poke put the ball ends in a can of oil and let it soak a while, then drip for a while /forums/images/graemlins/smile.gif
You can also rotate them in their socket while applying grease, works ok.
   / How do you lube 3PT ball joints? #3
I use aerosol white-lithium grease. It's nice since it doesn't drip afterwards.
   / How do you lube 3PT ball joints? #4
I used to lube mine.. but found they picked up dirt like crazy.. which then became an agressive grinding compound. I just let mine run clean and dry now.
Soundguy
   / How do you lube 3PT ball joints? #5
I spray mine with WD-40 and then wipe off the excess. That keeps the rust under control, and doesn't collect much dirt and gunk.
   / How do you lube 3PT ball joints? #6
Clean and dry, have been for oh, well the tractor is almost 30 years old with 8000 hours.
Wore enough they are easier to spin but they do still stick if left a month or two.
Ken
   / How do you lube 3PT ball joints? #7
Lockease spray graphite. Does not attract dirt. Also on the PTO splines.
   / How do you lube 3PT ball joints? #8
Like Soundguy, I leave mine dry, but then I live in a dry climate. I have some that have not been used in several years and they still spin freely.
   / How do you lube 3PT ball joints? #9
Grease and an old glove. They will rust and freeze up in about a week if they are not lubed with this weather. Just enough for a coat on them.
   / How do you lube 3PT ball joints? #10
I use motor oil, squirted on the balls and then rolled into the housing. I believe this is what my JD manual called for.
It has the disadvantage of attracting dirt which may cause wear, but it inhibits rust which also causes wear.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
