How do you guys store your subsoiler?
   / How do you guys store your subsoiler? #1
wksinatl
Bronze Member
Atlanta
case IH 485
the easiest way for me is to bury it in the ground (about 18") and just unhook it. It stays upright and rigid and makes it easy to hook up the next time. BUT, it seems like it might just be begging for rust by leaving it IN the ground. I would like to hear some better ideas. How 'bout it guys?
Keith
   / How do you guys store your subsoiler? #2
Keith, I think you have a good plan in place. The rust should go away after pulling it several yards. Keep the flat iron painted and you should be good to go.
   / How do you guys store your subsoiler? #3
is a sub soiler as good as having a tiller with the exception of it taking longer to break up the dirt
   / How do you guys store your subsoiler? #4
Here's an old thread that might be useful. Link A middlebuster stand should work for a subsoiler, too. It's probably better if it's not stored in the ground, but if it's outside, it will rust anyway.
OkieG
   / How do you guys store your subsoiler? #5
I have an old wooden hand truck that my subsoiler fits on. I store it inside and when I want to use it I wheel it out to my tractor. Works great.
Farwell
   / How do you guys store your subsoiler? #6
Lean it against a stump. Works great. Cost effective too.
   / How do you guys store your subsoiler? #7
I use the high tech approach, and hold mine off the ground with a jack stand. /forums/images/graemlins/wink.gif
   / How do you guys store your subsoiler? #8
If you want to keep it from rusting just spray a little Fluid Film on it. That'll keep it rust free until you need to use it again.
www.eurekafluidfilm.com
   / How do you guys store your subsoiler? #9
My tractor stays in the garage. Most of the attachments are on dollies. The house and garage are built of logs. For the combo subsoiler/middlebuster, I sank 2 eyelags into the logs, side-by-side, and just wider apart than the width of the toplink point on the plow. The tip of the plow sits in a drilled out hole in a large wooden block against the side of the log wall. The toplink then leans into the space between the eyelags. I slip a link pin through the lags and the toplink. Instead of a large clevis pin at the end of the link pin, I just slip in a padlock. Crooks ain't takin' it anywhere, and playin' kids ain't gonna' knock it over, break a toe, then get their parents to sue me. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2012 Ford F-350 Omaha Service Truck (A51692)
2012 Ford F-350...
