How do you determine a wheel manufacturer?
   / How do you determine a wheel manufacturer? #1
tnau664
Bronze Member
Piedmont, AL
Massey 231S
Need your help guys. I don't know what type hubs were used on the homemade axle for my log splitter:confused: . I would like to increase the size to 15 inch from the current 13, but don't now what type wheels will interchange. Does anyone know where I can check bolt patterns to determine the hub manufacturer? Current wheels are 5 bolt, 3 3/4 inches across the horizontal bolts.
Terry
   / How do you determine a wheel manufacturer? #2
Not that it can't be done, but I'd consider the hub's capacity for the 15" dia wheel. I'd say the hub / axle is aligned with the 13" wheel's load bearing.
The 13" - 5 on 3.75 is an odd pattern for the 13" wheel.
Weight distribution should not be an issue since this is an automotive hub on a log splitter that can't weigh more than 400 lbs. I agree, this is an odd pattern, just hoping I can convert without changing hubs.
   / How do you determine a wheel manufacturer? #4
I'm still looking. :D
   / How do you determine a wheel manufacturer? #5
Terry,
Did you measure correctly? 5 bolt at 3 3/4" spacing seems to be a very closely spaced pattern. Check at tirerack.com/wheels/tech then hit bolt patterns. the smallest they show for a 5 bolt pattern is a 4.00 spacing.
   / How do you determine a wheel manufacturer? #6
Pop the bearing cap off & measure from the center of the spindle to one of the lugs, then double that measurement. That will be your "bolt pattern" diameter. Typical 5-lug bolt patterns are 4.5", 4.75", 5", & 5.5". Atypical 5-lug bolt patterns are 4", & 4.625" (I'm sure there are a few more, but those are what I'm familiar with). Another method to determine bolt pattern on 5-lugs is to measure from the center of one lug to the far edge of another lug that is two lugs away from the first. If that totally confused you, then just check this page: MRW - How to measure bolt pattern
Thanks for the replys. I actually found a pair of rims on the World Largest Yardsale today. I live near the Southern end. Anyway, found these rims with tires mounted, measured the bolt cross section, and what do you know, it was what I needed. I poped one on a soon as I got home. Unfortunately, the guy that was selling them didn't know what they were supposed to fit. Go figure, but for $6 each, with decent tires, I couldn't turn them down. I'll never wear them out just pulling around my property.
Terry
Piedmont, AL
   / How do you determine a wheel manufacturer? #8
Terry
Piedmont, AL
Good deal. Highway 127 is good for something. It runs through TN as well.. :D
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2023 MDB GREEN CLIMBER F23-80 MOWER (A51406)
2023 MDB GREEN...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
19015 (A55788)
19015 (A55788)
