How do you clean your guns?
   / How do you clean your guns? #1
HGM
Veteran Member
Georgia
YM2000
This may seem like a simple question with obvious answers. However, I am refering to products and procerdures. So many of us have our systems and quirks, and I thought you guys might have good suggestions here. Please chime in.....
I'm currently using the Hopes kit that at some time, every one of us has likely used. Because of this, I can honestly say I dont shoot as often as I would like. Its dirty, time consuming to do it right and it stinks...Got a better way?
   / How do you clean your guns? #2
Boresnake! Boresnake! Boresnake! Boresnake! Boresnake! Boresnake! Boresnake! Boresnake!
I cannot overemphasise the value of this product. Especially with 22s which are notorious for being damaged by cleaning rods. I will still do a solovent based rod cleaning every 10 or so times to the range, but I'm telling you, there isn't much the boresnake doesn't get (powderwise). If you aren't using jacketed slugs, you may need to use something for lead fouling.
   / How do you clean your guns? #3
Your worried about damaging a bore with a cleaning rod and your using a bore snake? /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif
If you use the appropriate cleaning rod on any gun there will not be bore damage from the rod. Ideally that will be a one piece rod that is coated and there will be no damage from the rod. The bore snake is a great product for camping, hiking or in the field. Its also good for those who might not otherwise take the time to break a gun down and clean it.
I no longer use Hoppes except on shotguns. I prefer Shooters choice but that can not be used on case colored guns. I also use JB's bore polish from brownells spairingly when needed to remove copper/lead. The final touch on a shotgun bore is good old paste car wax. I use pledge or other furniture polish on stocks and never gun oil. I always use a bore guide on bolt guns.
   / How do you clean your guns? #4
Hi HGM,
Well alot depends on what type of gun Im using. If Im shooting skeet using maybe one of my Remington 1100, I take the whole gun apart. Well lets clarify that. I will remove the trigger assembly and clean the receiver area. I will remove the forearm and barrel assembly and clean the barrel and exhaust ports. Not sure if thats the right terminology. Clean the o-ring and associated parts on the shell magazine.
If Im occassionally shooting my Ruger 22 mag or 22-250 I usually do as the others and just clean the rifle bore, occassionally take the bolt out and clean that. The rifles that I shoot are much cleaner as powder goes compared to shooting the shotguns.
There are some very resonably priced cleaning kits on the market that will clean just about anything you have /forums/images/graemlins/grin.gif
scotty
   / How do you clean your guns? #5
We're supposed to CLEAN them?? uh-oh..............
   / How do you clean your guns? #6
I agree with getting a good one piece cleaning rod. Either wood or one that's coated.
There's plenty of chemicals out there to chose from. Sort of like picking the best oil for your engine. Try them all and pick the one you like the best.
The Marine Corps was very **** about cleaning our weapons. Inspections were with toothpicks and white clothe. Anything at all was enough to fail.
Automotive brake cleaner that you spray from a can cuts through oil and grease better than anything I've ever come across.
Some competive shooters I know say to only run a brush down a barrel the same direction the bullet travels. I make sure to push it all the way through before pulling it back up. No half strokes!!!
After the brush, I put the patch over the brush and put it down the barrel. Then I turn it over and use it again. I do this until it comes out clean. I also go through allot of patches!!!
I lubricate very lightly and plug the barrell with a few patches rolled together.
After cleaning, I know the first shot is gonna be off, so I take a few without really aiming. Then I'll check my group with three shots from a cold barrel. After each shot, I let the barrel cool. A hot barrel shoots different than a cold one.
I saw a guy at the range with four boxes of shells. His first couple of groups were all over the place, but then as his barrel heated up, his groups closed in. His second, third and fourth boxes of shells were all very well grouped. I asked about it and he said his gun shot better hot. He was pretty cocky and annoyed me, so I droped it and left. But to this day I wonder if he's ever killed anything with his first dozen shots while out hunting with a cold barrel.
Eddie
   / How do you clean your guns? #7
Cleanin' your guns is all part and parcel of the routine. It's a great opportunity to fill your kids up with huntin' lore and while you're at it --- some useful info like more safety and reloadin' tips, etc.
I manage to get about as dirty cleanin' my guns as I do when I grease and change the oil in my tractor. Started using those latex chore gloves a few years back...
I use Hoppes and Hoppes bore cleaner to remove the copper fouling. Also a bore guide on my rifles. And I fiddle and dawdle by taking the forearm off and the barrel off, etc. I don't pull the receiver out of my old Browning A-5's but will rinse them out with blazo (white gas) and then wipe down and re-oil. Kinda theraputic for me, I guess... /forums/images/graemlins/smile.gif
AKfish
   / How do you clean your guns? #8
I use the same as you and it works very well. I bought some swabs for the shotguns and a little pistol brush for the .357.
The only thing I have to advise you is to take the weopons out into your garage or workshop, lay news paper out and do it when you are doing garage things. If you have just changed the oil in your tractor or sharpened the blade on your mower then cleaning your guns seems like pretty clean work....
   / How do you clean your guns? #9
I have been a little guilty of letting the dirty guns stay dirty. My Rem 870 12 gauge pump shotgun gets very dirty and stays that way but it's a shotgun for crying out loud. I do clean it every few outings. Almost exclusively shoot clay pigeons.
The Ruger 10/22 .22 cal auto rifle has gone through thousands and thousands of rounds. It has been cleaned but only occasionaly. This is my plinker that I bought 13 years ago from a pawn shop, I highly recommended this rifle to anyone.
The Ruger 40s&W I carry gets cleaned after every shooting and the 30-06 also gets cleaned each time. These guns need to work and work well every time. The first two guns run very well without cleanings.
By cleaning I still use the hopps style kit of swab with solvent, brush with solvent, swab dry, swab with oil. The bores get clean and oiled and the outside parts get oiled to prevent rust. I bought a can of spray lube by remington to shoot into areas that I think need it but can't reach with the swab. The swabs are cheap, buy a big package of them.
   / How do you clean your guns? #10
I clean my gun in the shower. (Sorry, flashback to boot camp!) /forums/images/graemlins/smile.gif
Hard to beat a good, coated cleaning rod and some Hoppe's, Q-tips, clean rags, lite coating of oil. Boresnake for in the woods when a full clean isn't practical. My firearms are routinely disassembled, cleaned and reassembled...though I can no longer do it with my eyes closed!
Semper fi!
Pete
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
1273 (A50490)
1273 (A50490)
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
