How do these prices sound?
   / How do these prices sound? #1
Anonymous Poster
Epic Contributor
I am leaning heavily toward orange since the prices I am getting on comparable green tractors are way higher. Now I just have to figure out which one...
B2900HSD $13295
B2700HSD $12095
FEL for 2900/2700 $3095
B2410HSD $11395
FEL $2995
B7500HSD $9795
FEL $2695
BX2200 $8895
FEL $2395
Landpride 5’ rear finish mower $1695
(prices from my Kubota shopping trip in Houston TX)
No comments? I thought they were pretty good. I'm not done shopping yet.
   / How do these prices sound? #3
Hi,
I'm not up on the latest prices, so I can't be of too much help. They certainly look O.K., but that's just my opinion.
I noticed you didn't get a quote for a B7800. Any particular reason? It might round out the lot, so to speak.
Also, you seem to be interested in quite a range of tractors. Without specific regard to your actual needs, your prices do reflect something that I found when I was looking at the B series 3 years ago. That is, if you compare the loader price between a BX2200 and the LA402 for the B7800/B2710/B2910, you find that about a 25% increase in cost gets you about a 90% in lift capacity, plus a larger bucket and greater lift height.
I've found this to be true with most implements. So, again, the bigger tractor will give you more for your $$$.
It's because of this that so many of us on this board often recommend the biggest tractor you can afford that fits your needed applications. You just get more bang for the buck. Of course, a huge tractor does you no good if you can't maneuver it where you need it, so eventually a little bit of sanity is needed.
Good Luck in your decision. Sounds like you've got nothing but winners in your sights.
~Rick
   / How do these prices sound? #4
My B7500HST is a year old now, and I spent a few hundred more than that when I bought mine. I shopped three different Kubota dealers, and the other two were $750 and $1,500 more than I paid....................chim
   / How do these prices sound? #5
not being up on the current prices, i can only go on what i ahve seen on this forum, but the prices all seem reasonable. but u are talking a wide range of machines, which one will do the best for your needs? how much land and what kind of uses? will have an awful lot to do with what machine u need. a low price won't do u much good if the tractor can't do what u need it to do.
Sorry guys, I posted the land/use info in the General Forum. I pretty much narrowed it down to Kubota now because they are running a lot less than JD for a comparable setup. Land/use info below:
Have a house outside of Houston TX on 4 acres. Mostly flat all open no trees or obstacles. The property does slope off to a pond and grass right up to the water almost. All along the front and side there is a 15-20’ wide V-shaped drainage ditch which needs to be cut. Some of the “field” part is smooth other parts are rough with 6-12” clumps of grass in some areas, some areas eroded near the pond, some areas are muddy and some areas are pretty rough not to mention the sometimes foot high fire ant mounds. Photos Here!
Have a Scotts 20hp 48” cut riding mower. The Scotts is fantastic for cutting the nice St. Augustine sod that is around the house but once in the field it isn’t as good. It gets the job done but I feel I am tearing it (& me) up trying to cut everything. On the grass clumps the ride is like riding over bowling balls. The eroded areas I have to stay away from as the holes will swallow the tires and the thing gets stuck even it a little standing water. It does the drainage ditches pretty well with a few areas being just too steep. The Scotts will be kept for around the house.
About 90% of the use of the new tractor will be cutting the grass. I want to smooth out the rough, bumpy and eroded areas. We have some areas that are low and need to be filled with dirt for better drainage. We have too much landscaping and I want to move 10 cubic yards of mulch around in the spring and about 5 or so touch up in the summer. So a loader is definitely in!
I forgot to price the 7800, but I got a price of $12,400 at a second dealer (whose prices were a few hundred more on everything than the first dealer).
I find the BX to be too small. Yes it’s a “real tractor” (as one of the salesmen told me /forums/images/graemlins/shocked.gif) but it’s not much bigger than my Scotts. I know my property and it would swallow up the BX.
I got to use my neighbors L3000, it was nice but a little too big for what I need, plus it left a few dents from the ag tires in the yard when I used it to spread some mulch.
I am leaning heavily toward the 7500, it sounds like it should be good for what I want to do with a tractor. My only reservation is do I want/need to go bigger and more powerful? There is only about a $2700 difference between the 7500 and the 2710 or the 7800. I would easily pay that IF it would be beneficial to me but I don’t want to go too big for only 4 acres. I was trying to stay around $15,000, the 7500 would be a little under that and the 2710/7800 would be a little over. Again I would pay the extra if I really need it. DO I???
Well I have just gotten a B2910. I love it. I paid 15,600.00 for it with 402 FEL. A man I work for has a B2410. It is an okay tractor. A friend of mine bought a B7500. He paid 12,200 with 302 FEL. I have used the B7500 and the B2410. I donnot care for the B2410. As far as power goes I would just as soon have the B7500 as the 2410. I would either get the B7500 or the B2710. If you want to spend the extra money get the B2910. It is all about your budget. You will be happy whatever you get. Just some advice
   / How do these prices sound? #8
I checked out your pictures - wonderful place you have, there.
<font color="blue"> I am leaning heavily toward the 7500, it sounds like it should be good for what I want to do with a tractor. </font>
You want something along these lines with either a brush hog or a rear mounted fininsh mower. You are definately on the right track, IMHO.
<font color="blue"> My only reservation is do I want/need to go bigger and more powerful? </font>
My only regret is that I didn't /forums/images/graemlins/laugh.gif. But realisically, my tractor is up to everything I've asked of it. Bigger would be OK, but what I have works really well for me.
   / How do these prices sound? #9
Remmington Trails?
I'm in Katy too. Which dealers have you dealt with and where did you wind up buying? I looked at Roach, but I bought a car from their Ford dealership once and was very dissappointed in the service. I realize these aren't cars, but I just can't seem to get the bad taste out of my mouth.
Hi Keith,
Yes, Remington Trails. Did the white fencing give it away? /forums/images/graemlins/smile.gif
I went to Roach first because it was closest. Jack and another guy there have spent some time with me and I had a couple test drives there. I first thought their prices were good but it seems their tractor prices are just a little ($0-$200 or so) below everyone else but their add-ons (FEL, cutter, BB) are all $150-$200 each more than everyone else. So the lower tractor price is wiped out and then some by the higher implement prices. Pickup & delivery on warranty service is up to you, they might pickup if in your area or you can borrow their trailer. 50hr service is on you too. They are very knowledgeable on their tractors thought and have answered all my questions.
I went to Sealy tractor next (Virnau) & talked to Donny. Their prices were all a few hundred dollars higher and they mostly deal with the bigger farm tractors. Donny was helpful and could get in whatever I wanted but I haven’t been back because it’s further out and their prices are higher.
Last Friday I went to Lasndowne Moody on 290. They have a full line in stock of the B series I am looking at, it was nice to look at them all side by side. Their prices were equal to or $100 more than Roach on the tractors but $150-$200 each less on the add-ons. They do offer free pick up and delivery on warranty work and 50hr service and 50hr service is free labor you pay parts. I have to take another trip there and talk to them some more.
I haven’t decided on dealer but leaning toward Landsdowne, but all 3 dealers seemed decent. I haven’t decided on tractor but leaning toward 7500. I have a few more questions to ask and a bit more research to do.
So which dealers have you delt with and what experiences have you had. Where is your soon to be cattle ranch in Katy? Oh and the 3130 is really sweet from what I saw, nice choice!
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A55787)
2025 MS380R Mini...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
