How do I work the Hydrolic controls on a '48 Ford 8N?
   / How do I work the Hydrolic controls on a '48 Ford 8N? #1
esks5953
Torrey, Utah
'48 Ford 8N
Specifically,
How do I engage the hydraulic controls to:
a: Raise and lower the front implement (plow blade)?
b: Raise and lower the rear 3 Pt Hitch gear, with or without an implement attached?
Thanks!
   / How do I work the Hydrolic controls on a '48 Ford 8N? #2
On these N series fords you need the pto engaged to raise the 3 pt hitch regardless of wether there is an implement attached or not. My recollection is that the pto engagement lever is by your right leg by the seat. If not then on your left. Once the pto is engaged you lift the lever on the quadrant on your right to raise the lift arms for the 3pt. I dont know how yiur front blade gets its hydraulics but if it feeds off the pump for the 3pt then this same procedure will activate the hydraulic fir that. Then look forca lever on a spool for the front blade. If that doesn't get your front blade going then post some pictures.
   / How do I work the Hydrolic controls on a '48 Ford 8N? #3
Aldo the clutch needs to be engaged...in oyher words take your foot off the clutch pedal.
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
CATERPILLAR 299D3 SKID STEER (A51242)
CATERPILLAR 299D3...
Danuser Digger F-8 (A52128)
Danuser Digger F-8...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
JCB 3TS 8T SKID LOADER (A51242)
JCB 3TS 8T SKID...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
