3-Point Hitch How do I increase my hydraulic pressure on 1655 garden Tractor
   / How do I increase my hydraulic pressure on 1655 garden Tractor #1
dcotton4
Northwest Missouri
Massey 1655
I recently added a category 0 3 point to the rear of my 1655 garden tractor and dont really dont have the amount of lift I think I should. Can I increase the hydraulic pressure the hydro will put out?
   / How do I increase my hydraulic pressure on 1655 garden Tractor #2
:welcome:
What pressure do you have now?
Ah I fixed it! I looked at the parts diagram and seen where there are shim washers you can add to raise the pressure on the relief valve. It didn't have any on it so I added one 1/16" shim and it works great now. I can stand on my rear mount blade and it will raise me right up no problem( I way 215lb).
   / How do I increase my hydraulic pressure on 1655 garden Tractor #4
good deal :thumbsup: I like those easy fixes .
   / How do I increase my hydraulic pressure on 1655 garden Tractor #5
Just for your info the implement relief valve should be set at 900-1000 psi don't go any higher.What happens if it's set to high is that the rotor in the charge pump is driven by a small pin.Too much pressure and the pin will break and usually when that happens small pieces of metal score the pump etc: then it needs to be refaced.Ask me how I know.Larry
Sounds like I better borrow a gauge and check my max PSI just to be safe.
   / How do I increase my hydraulic pressure on 1655 garden Tractor #7
Yes, that is a good idea. They are only $20-much cheaper that hydraulic parts.
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
2015 Nissan Sentra Sedan (A50324)
2015 Nissan Sentra...
20306 (A51694)
20306 (A51694)
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
CFG Industrial QK20R (A50121)
CFG Industrial...
