How do I hook up this spool valve?
   / How do I hook up this spool valve? #1
gsdavis1
Cleveland, OHIO
John Deere 855
I have a Bolens HT23 that I am going to try to retrofit with power steering parts from a John Deere 420. It consists of a steering column attached to an orbital valve. The valve has ports labeled "in" "out" "left" "right" and "aux". My question is can I just cap the "aux" port? I wouldn't want to ruin my pump but I dont think I need the "aux" port. John Deere has it going to the deck lift cylinder I think (not sure though). Or maybe I should use it to add another power beyond port???? I have included a picture of the parts I bought.
Thanks for all your help guys.
Greg
   / How do I hook up this spool valve? #2
The steering control unit is an orbital valve that probably has an integral priority flow divider, since there were apparently downstream devices on the John Deere. And the integral priority flow divider in an orbital steering valve (unlike flow dividers that are connected directly to the the pump outlet) probably sends the entire pump flow through the "aux" port when the steering wheel is centered and may send the entire pump flow through the steering valve when turning the wheels rapidly against a load.
If so, the aux port cannot be blocked since that would deadhead the pump. The aux port should be connected to either a downstream valve (open center) that exhausts to the tank, or the aux port should be tee'd into the "out" port where it can exhaust to tank.
Thanks, I will probably just tee it into the out port back to the tank then.
Greg
   / How do I hook up this spool valve? #4
I am converting my John Deere to PS with 5 port can the AUX port feed the hyd for lifting mower or snow plow since they have return to no dead head pump
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52748)
Quick Attach Skid...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
