How do I 'float' the scv(FEL) on my JD2320?
   / How do I 'float' the scv(FEL) on my JD2320? #1
ragkar
Platinum Member
eastern PA-lower Poconos
JD2320 w/R4 $21,100 w/7.16%off
On a previous thread, you guys advised me to 'float' the 3ph by moving the rockshaft control lever full forwards. I haven't tested that because I now have my BH on and I'm reluctant to take it off because it was so difficult to attach. but I think that you're right.
On another thread on backfilling there was talk of floating the FEL so I decided to check my manual.The JD operators manual for the 200x/cx advises the operator to float the loader in three places, but it doesn't say how to do this.
So how do I float the FEL?
To answer my own question using the operator's manual for the 2320 I quote "Move the lever to the full forward or 'float' position to remove pressure in both connector lines ..."
Fine, except that when I tried that it lifted both front wheels off the ground. I don't think that's 'float' as I understand it. What am I doing wrong?
   / How do I 'float' the scv(FEL) on my JD2320? #2
push the lever past the detent when it starts lifting your front wheels. it's their because i had the same concern.:D
   / How do I 'float' the scv(FEL) on my JD2320? #3
This is easiest to get the feel for when the machine is not running. Push the lever forward until you feel a stop. This is the position you use to lower the bucket. From here, "pop" the lever forward just past this first stop. This is the float position. Once you can feel it with the machine stopped, go ahead turn the engine on, bring up the RPMs and raise the bucket. Move the lever forward to lower the bucket. When the bucket contacts the ground and just before you feel the front end of the tractor lift off the ground, "pop" the lever into the float position.
You're right! I just had to go out there to check even though it's dark out. Thanks for the quick reply.
   / How do I 'float' the scv(FEL) on my JD2320? #6
I was wondering the same thing! Thanks for the question and answer. (I waited till first light to check mine!)
   / How do I 'float' the scv(FEL) on my JD2320? #7
I had a 2320 for 9 years and never knew it did this. DOH!
   / How do I 'float' the scv(FEL) on my JD2320? #8
SilencedNine
Welcome to TBN
And kudos for finding some of the real benefits of TBN
Newly married?? ;)
1982 MACK RD685S HOTOILER (A50854)
1982 MACK RD685S...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
