How do i determine 3 point top link length i need?
   / How do i determine 3 point top link length i need? #1
DENALIAKITAS
Bought a tractor and it is missing the top link for the 3 point. I am wanting to pick one up but i am not sure how to determine the length i need. Thanks
   / How do i determine 3 point top link length i need? #2
What kind of tractor? Cat 1 or cat 2 hitch?
   / How do i determine 3 point top link length i need? #4
Probably either 20" or 24" body top link. I'm thinking 20 " will adjust 24 to 36".
   / How do i determine 3 point top link length i need? #6
Raise your hitch so that the draft arms are parallel with the ground. Now measure from the top link pin on the tractor out to where you are out as far as the pins on the draft arms. Have the tape measure parallel with the arms. This will get you what should be your true mid stroke length. Then go find a top link that is close to that measurement when it is at it's mid way adjustment. There should be an extended and retracted measurement available when you are shopping. Get one that matches your measurement when you figure the new top links mid adjustment length.
Good luck ;)
2015 John Deere X730 54in Ride-On Mower (A42744)
2015 John Deere...
2014 Ford E-150 Cargo Van (A44571)
2014 Ford E-150...
Pallet of Irrigation Hoses (A44502)
Pallet of...
2008 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2008 ADVANCE...
1997 FORD SINGLE AXLE DUMP TRUCK (A43004)
1997 FORD SINGLE...
Toro Groundsmaster Crosstrax 4300D AWD 90in Contour Rotary Mower (A42744)
Toro Groundsmaster...
