how do I control more than one piece of equiptment ?
   / how do I control more than one piece of equiptment ? #1
Carlton G
Rustburg, Virginia
John Deere 990
i have a John Deere 990 with a front end loader. How can I run a Woods stump grinder without removing the loader.
   / how do I control more than one piece of equiptment ? #2
Is it PTO driven or hyd powered?
You have 35 HP at the PTO.
You have about 9 HP using the hyd.
If hyd, you could use a PB from the loader valve to feed the stump grinder.
Hydraulics:
Type: open center
Capacity: 5.5 gal [20.8 L]
Pressure: 2262 psi [156.0 bar]
Pump flow: 8.5 gpm [32.2 lpm]
Total flow: 13 gpm [49.2 lpm]
Steering flow: 4.5 gpm [17.0 lpm]
You don't have a lot of fluid for a stump grinder.
Have you looked at the stump grinder hyd requirement.
   / how do I control more than one piece of equiptment ? #3
Post a link to the model of Woods stump grinder you plan on using. It would be helpful.
   / how do I control more than one piece of equiptment ? #4
Oh yeak I almost forgot.... Welcome to TBN! :welcome:
   / how do I control more than one piece of equiptment ? #5
I have a Woods TSG50, I'm pretty sure he's asking about adding rear remotes to run the two double acting cylinders for up/down left/right movement. The grinding wheel is PTO powered.
The Woods TSG50 can operate off two sets of rear remotes, or one pair with either the manual or electric selector valve kit from Woods for the stump grinder.
   / how do I control more than one piece of equiptment ? #6
If it has a loader you could always put in quick connects and use the loader controls to operate the stump grinder, however, you'd be facing the wrong way for controls and have a spaghetti knot of hoses. Maybe not a good idea.... :laughing:
I'm used to having all my implements out front. :rolleyes:
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2006 KENWORTH (INOPERABLE)T800 (A55745)
2006 KENWORTH...
Informational Lot - Shipping (A57024)
Informational Lot...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
