How do I connect my post pounder
   / How do I connect my post pounder #1
MWRR
East Central Illinois
John Deere 5105M & IH Farmall 544
Have a 5105M with deluxe triple remotes. I have a Shaver (I think that is the brand) hydraulic post driver. It has one high pressure line fitted with a pioneer fitting that raises the cylinder and a large low pressure return line (it basically just dumps hydraulic fluid back into the system) that I insert in the hydraulic fill opening on my IH 544. The high pressure line fitting should fit in my SCV on my Deere. I don't know which one of the three remotes I should use on my 5105M and which of the three settings (bucket, detent or hydraulic motor) I should have the remote set on. Can anyone help me?
   / How do I connect my post pounder #2
The bucket setting should be the one you want to use. The key is the low pressure return-you probably will have to put the hose in the fill cap just like you did on your IH.
Thanks Kennyd.
Informational Lot - Financing (A55302)
Informational Lot...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
