How do I check hydraulic/trans fluid level?
   / How do I check hydraulic/trans fluid level? #1
oldyeller
Ontario,Canada
Satoh Beaver III S-373-D
I have a beaver III S-373D. I assume there must be a bolt to remove or something to check the hydraulic/trans fluid level but I can't find any info in the instruction book.The filler hole is in the topside of the trans with a small rubber plug but no dipstick.I need help as my hydraulic cylinder that lifts my snowplow is leaking and I lost a fair bit of oil and I need to top it back up.Help /forums/images/graemlins/confused.gif
   / How do I check hydraulic/trans fluid level? #2
The level plug is on the left side of the transmission about the height of the foot rest just in front of the LH axle housing. Add oil till it flows out the hole. Email me at vppinc@rev.net and I can send you a drawing of the area or call 800-609-5110 if we can help further. Bill Rodgers
Thanks very much.I'll take a look and see if I can find it.
   / How do I check hydraulic/trans fluid level? #4
I had same question and here is the answer.
(APPROX 20) 2" X 3" X 49" TUBING (A51247)
(APPROX 20) 2" X...
2012 Ford F-450 Knapheide Service Truck with Liftgate (A51692)
2012 Ford F-450...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
Miscellaneous Pallet of Road Safety Signage (A52384)
Miscellaneous...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
