How do I attach fuel fill door?
   / How do I attach fuel fill door? #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Seriously! I am really not that mechanically challenged. But I have no idea how to connect the fuel door. Where did a little Springs go? I've tried this before and gave up and now I'm back at it Can someone take a picture of an intact unit? Has anyone successfully replaced one of these? Help! TIA!
This is on a 4310 - I imagine most are similar
   / How do I attach fuel fill door? #2
I know the issue you're having. It is a whole lot easier to look at one in-person.
The spring doesn't go as you would think - which is to put the hinge pin through the spring coil. Don't do that - although that does look to be the obvious orientation.
The tag ends of the spring engage with the flap (door) and the Bonnet (Hood) itself. Then the hinge Pin is installed. The coils face the rear (Towards the steering wheel).
You really do need to see another one but I hope this helps. Perhaps go to your dealer and take pics. Or someone here can post pics. Close-up's pls.
You need the two rubber bump-stops to be there so the 'door' doesn't over-close which reduces the tension on the spring and it can fall out.
   / How do I attach fuel fill door? #3
By jd parts, looks like it is a bit different from my 4300, and may be different at a s/n break for the 4310
Take a few pics to post of the parts you are working with... then maybe we can point you in the right direction.
   / How do I attach fuel fill door? #4
I don't think the hood on my 4300 is original so it might be similar to your 4310.
Wow! Thx. I will try - I am pretty sure that is what I was trying- but knowing for sure that is the setup will help immensely.
   / How do I attach fuel fill door? #6
Good pics Tex.
Rocky: you can also see the rubber buttons there in Pic.1. The tails are about 30mm long so you can pull them down from the underside.
I hope you got your springs installed ok.
   / How do I attach fuel fill door? #7
They are areal pain to get hooked. For small springs they are very stiff. Be careful not to break the plastic hood when getting them connected. Needle nosed pliers, maybe 90 degree or 45 degree seem to work best I think.
It is on, and epoxy is now set on the small crack.
Thanks to all!
   / How do I attach fuel fill door? #9
Glad to hear you got it fixed!
   / How do I attach fuel fill door? #10
Thanks for the pics and info.now maybe I'll get mine installed.
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
Trojan 35CL 40 mm Hydraulic Hammer, NEW (A52384)
Trojan 35CL 40 mm...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
Eagle Line 3pt Single Row Plow (A50123)
Eagle Line 3pt...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
