How do I adjust the two-stage clutch on a KiotiLK3054 other than the pedal linkage ?
   / How do I adjust the two-stage clutch on a KiotiLK3054 other than the pedal linkage ? #1
BonesRacing
Sapulpa, Ok
Kioti LK3054
How do I adjust the clutch on a LK3054 other than the pedal adjustment, the tractor wont pull at all. PTO still works and loader still operates. Just wont untrack. anyone know anything about adjusting the two-stage clutch? thanks,...Bones
   / How do I adjust the two-stage clutch on a KiotiLK3054 other than the pedal linkage ? #3
Just answered your IM. If you're experiencing a drive issue I can give you the procedure as per the 3054xs manual, but it doesn't sound like a clutch issue if your PTO still operates, unless the drive clutch itself is compromised, in which case the tractor must be split. Check to determine all drive related controls operate as intended, i.e. the shuttle, high/low range selector and the gear selector itself. I once lost the roll pin that attaches the gear selector on the dash to the transmission; tractor would not move and I was sure I'd really screwed something up until I found the selector moving but the transmission was not shifting. That roll pin still works it way out occasionally and must be reinstalled
2020 KUBOTA RTV...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
12in Excavator Bucket (A50322)
12in Excavator...
2005 MACK GRANITE (A52472)
2005 MACK GRANITE...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
