How Can I Tell a 3-way From a 4-Way FEL Control
   / How Can I Tell a 3-way From a 4-Way FEL Control #1
boustany
Platinum Member
Campbellville, Ontario
Kubota L3010, BX2200
I read on a TBN post that a 3-way valve can't run a hydraulic motor, and that, it won't work with my FEL if I swap the hoses (up & down reverse).
Well, I NEED to know if my FEL control on my 3010 is 3 way or 4 way. I swapped the hoses and the FEL works perfect (besides being backwards).
Any other suggestions? This is gnawing on me ...
   / How Can I Tell a 3-way From a 4-Way FEL Control #2
Assuming you have the LA482 loader, is the part number on the valve serial number tag an L2205 or L2207? The 05 is the 3-way and the 07 is the 4-way. The L2205 was standard equipment.
thanks - I'll check!
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
Brush Bandit 200UC Towable Brush Chipper (A52377)
Brush Bandit 200UC...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
