How big is hay bale?
   / How big is hay bale? #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I am adding a hay storage to existing barn and it will be basically a cube 10x10x8 feet - how many square bales is gonna fit there?
Somebody told me 16'x18"x48" - is it correct?
Thank you
   / How big is hay bale? #2
The bales vary in size. I have a 20x40 run in shed with one end boarded up that we store the hay in. It's about 20x10x10 plus the peak. We can usually get around 250 regular sized (60-80lbs) bales in there stacked to the roof.
   / How big is hay bale? #3
also wanting to know for my barn project that is in the planning phase.
also looking for a weight as im seeing what i can put up in the "attic" for storage.
<edit>
based on whats listed above your looking at like 10lbs per ft^3 ??
Thanks, spark_man, that gives me some clue.
How was the joke?
You may be a redneck when you know how many bales of hay your car will hold:D
   / How big is hay bale? #5
2003 Honda Civic, No passengers
Inside - 3. 4 if they are small
Trunk - 2
Roof & trunklid including the back window - 8
I tried the hood but I just can't see :(
   / How big is hay bale? #6
Impossible -- you can't even begin to think about being a redneck until you have a pickup for the hay.
   / How big is hay bale? #7
You can store 4 tons of hay in a 12x12 stall. The number of actual bales varies greatly depending on which bailer was used and how it was adjusted.
   / How big is hay bale? #8
i have to dissagree the essence of redneck is useing something as it wasnt intended.
he11 a pickup is supposed to haul stuff...
but 5 hay bales packed into a civic....
priceless
   / How big is hay bale? #9
I once put 15 in a Ford Aerostar minivan ;-)
AND
I loaded 54 on a Chevy crew-cab, dually.
GOD - I AM A REDNECK - BY BOTH STANDARDS!
   / How big is hay bale? #10
Spark_man:
Only 54 on a CHEV dully. My old Ford F150 would hold 75 on average. We maxed out at 85 one trip. Never again...
Lloyd
New/Unused 2 Post Car Lift (A44391)
New/Unused 2 Post...
2013 FREIGHTLINER CORONADO (INOPERABLE) (A45333)
2013 FREIGHTLINER...
GENIE GS4046 (A45046)
2011 FREIGHTLINER CORONADO 122 SD (A45333)
2011 FREIGHTLINER...
2013 CAT D6K2 XL Dozer (A42203)
2013 CAT D6K2 XL...
2016 Chevrolet Malibu Sedan (A42744)
2016 Chevrolet...
