How big a box blade for MF 65??
   / How big a box blade for MF 65?? #1
maz
Ontario, Canada
None Yet
Hi all, just wondering what size box blade would be good for a MF65? don't want to buy one and find out it's too big. 6FT, 7FT, or 8FT?
   / How big a box blade for MF 65?? #2
Whats your tire width?
Not 100% sure, gonna measure tomorrow, but I think it's around 72".
   / How big a box blade for MF 65?? #4
The use of a box blade is quite important in looking at its size. If you're going to be moving relatively dry earth around on a relatively flat surface, your MF 65 should be able to pull a pretty wide BB. However, if you use it on gravel on slopes, your tractor probably should look at 6 foot max. My old JD 2030 with probably about the same weight as your tractor, but with 68 hp or about double yours, struggled to pull a 6 foot BB on a fairly steep gravel drive. While it handled it easily on the flat, the hill would sometimes just stop it dead. I downsized to a lighter JD CUT with 38 hp but less weight than yours, and could not pull the 6 foot BB on any hill... Although it did manage flats. I actually downsized the BB to 5 ft and it now handles is pretty well. So the bottom line is the use and slope for your BB. If you buy new, a dealer may let you try it out and go for a different size if it can't pull it. If not, I'd suggest getting a 6 foot max and seeing how it goes. You can usually find someone on CraigsList to swap with to up or down in size.
Some folks like the have the BB wide enough to cover your tracks. Again it depends on your use. With gravel drive maintenance, that really doesn't matter. Just being able to pull it smoothly does.
But, again, if you are just moving dry soil around you can shoot for a bigger blade.
   / How big a box blade for MF 65?? #5
i'd go 6'. it should drag just about anything in that box at that width.
Thanks for the input guys, I was planning on a 7' to "cover my tracks" but I'm going to be using it for a variety of tasks. Which include grading and maintaining a gravel drive and pulling dirt and leveling for landscaping around the house. I do have some smaller hills with a slight grade.
I think with the reasoning you guys have given a 6' blade should work and when I get out to measure the wheel track tomorrow it may be 6' to the outside of the rear wheels anyways.
   / How big a box blade for MF 65?? #7
or could be made to be.. :)
Well both the front bucket and wheel track width is 75inches, so I guess a 72inch box blade its what I'll be ordering.
   / How big a box blade for MF 65?? #9
sounds good!
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
