How bas is it?
   / How bas is it? #1
Bfitzgerald3
Bronze Member
Harbor springs, mich
Kubota Mx5100
I got a soil test done before diving into growing anythng... "less than optimum" is plastered all over the report.
Lime index:69
Ph: 5.5
Phosphorous :17ppm
Potassium:24ppm
Magnesium: 20 ppm
Recommended 2 tons/A dolomite lime and 100 lbs per acre Nitrogen
   / How bas is it? #2
Ya, your Ph isn't good. You want to be closer to 7. My experience is that without adding lime to get the acidity out of the soil you will just throw money away on seed and fertilizer. By the way it takes awhile for the lime to do it's job.
MarkV
   / How bas is it? #3
If you are looking at seeding clovers or alfalfa, best wait until you get the pH up to a minimum of 6.2 to 6.5. Grass hay does not need to be quite as high before seeding, but does help if it is up there too. If legumes have not been grown in the field before, you may want to inoculate the seed also when you do plant for better nitrogen fixing. Good luck.
2009 Ford F450 Dump (A47384)
2009 Ford F450...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
2015 Nissan Sentra Sedan (A50324)
2015 Nissan Sentra...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
2014 International 4400 DuraStar Box Truck (A47384)
2014 International...
