How and Where do you "lubricate the selctive control valve?
   / How and Where do you "lubricate the selctive control valve? #1
stuart
Virginia, Eastern Shore
JD 4300
I own a 4300 JD hydro and was doing a 10 and 50 Hour service when I came across the instruction to "lubricate the selective control valve (if applicable)" under the 10 hour listing in the manual. The 50 hour instruction just said
"lubricate the selective control valve".
I could not figure out WHERE TO LUBRICATE the SCV. I am not experiencing any problems with it at this time.
Any assistance would be greatly appreciated.
   / How and Where do you "lubricate the selctive control valve? #2
I would just hit the linkage pivot points with some spray lube.
   / How and Where do you "lubricate the selctive control valve? #3
Where the joystick attaches to the tractor there are ball joints. Silicone spray lube works well because it does not attract dirt.
Thanks: Should I remove the black plastic cover held on by 3 or 4 screws to get to the lube points, or can I just spray the lube behind the cover onto the ball joints?
   / How and Where do you "lubricate the selctive control valve? #5
I would remove the cover and give everything a wiggle just to make sure nothing is getting ready to fall off...
Thanks Kenny: Will do and while I am at it. Thanks to this website for helping to keep me and others like me who did not grow up around farm equipment safe and aware of the dangers that exist.
   / How and Where do you "lubricate the selctive control valve? #7
(Very) late to the party here -- but for future folks finding this chain... You can also just squeeze then lift up the rubber boot on the SCV control stick to expose the linkage. The boot just has a small lip holding it in place.
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2018 Ford F-350 4x4 Crew Cab Service Truck (A51692)
2018 Ford F-350...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 164 (A53084)
2020 JOHN DEERE...
TEYME 2000 E0L0 GTE10 LOT IDENTIFIER 62 (A53084)
TEYME 2000 E0L0...
Tafe 45DI (A50123)
Tafe 45DI (A50123)
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
