How about...
   / How about...
Specifications
Engine Manufacturer Yanmar
Model Number 3TNV82A
Type Diesel
Gross Horsepower 19.8 kW (26.5 hp)
PTO Horsepower 14.9 kW (20 hp)
Cylinders Three
Rated Engine Speed 2600 rpm
Operating Range 1000 - 2750 rpm
Oil Filter Standard Single Element
Air Cleaner Dry Type, Two Stage
Drivetrain
Type 2 Range Hydrostatic
Number of Speeds Infinite
Mechanical Front Wheel Drive (MFWD) Standard
MFWD Capability All Ranges
MFWD Engagement On The Go
Final Drive Spur Gear
Rear Axle Maximum Load 1100 kg (2426 lb)
Front Axle Maximum Load 880 kg (1940 lb)
Electrical System
Type 12 Volt
Battery Size 500 Cold Cranking Amps @ -18°C (0°F)
Alternator 20 amp
Front Wheels and Tires
Standard 24x8.5-14 R3
Optional 23x8.5-12 R4
Rear Wheels and Tires
Standard 36x14.00-15 R3
Optional 14-17.5 R4
Fluid Capacities
Fuel Tank 27 L (7.1 gal)
Cooling System 3.9 L (4.1 qt)
Crankcase with Filter 2.8 L (3.0 qt)
Transmission and Hydraulic System 14.6 L (3.9 gal)
Front Axle 3.4 L (3.6 qt)
Ground Speeds
NOTE: All ground speed calculations shown are with machine equipped with standard tires and operated at 2600 engine rpm.
Forward and Reverse - Range High 0-20.9 km/h (0-13.0 mph)
Forward and Reverse - Range Low 0-7.2 km/h (0-4.5 mph)
Dimensions
NOTE: Machine equipped with standard tires.
Wheelbase 1655 mm (65.2 in.)
Overall Length with 3-point Hitch 2766 mm (108.9 in.)
Overall Width (Minimum) 1295 mm (51.0 in.)
Tread Width @ Centerline (Minimum)
Front (Only Wide Position Recommended) 923 mm (36.3 in.)
Rear (Only Wide Position Recommended) 954 mm (37.6 in.)
Height From Ground
To Top of Hood 1190 mm (47 in.)
To Top of ROPS 2279 mm (90 in.)
Ground Clearance
Front Axle 320 mm (13 in.)
Rear Axle 260 mm (10.2 in.)
Turning Radius
With Brakes 2.3 m (7.5 ft.)
Without Brakes 2.5 m (8.2 ft.)
Weight
Machine equipped with a ROPS, 3-point hitch, standard tires and all fluids. 846 kg (1865 lb)
3-Point Hitch
Type Category 1
Lift Capacity-61 cm (24 in.) behind link arms 522 kg (1650 lb)
Lift Capacity-at link link ends 650 kg (1433 lb)
   / How about... #3
O Boy Here we go again, LOL. Can't wait to see the pic's of this model /forums/images/graemlins/grin.gif
Jim
   / How about... #4
Rockyridge.... I tell you...You Da' Man!!! I now wonder if this Post will get as much attention as the Shhh..2305 Post has! This tractor and specs look good, and I'm glad to see they're keeping the HP rated at a lower RPMs unlike some modern trends. Also, would I be considered greedy if I wished there was a Post with info. on the new 2320 as well???
   / How about...
<font color="green"> glad to see they're keeping the HP rated at a lower RPMs unlike some modern trends. </font>
I think that is a SubCUT thing. They are primarily mowers, and are competing with LGs aith B&S gas engines, so I think all manufacturers are doing that there...
2320,, sniff... sniff.... /forums/images/graemlins/cool.gif
   / How about... #6
Does anyone else fine it odd that the 2520 manual is specifically for just the 2520 and no other 2x20 series tractors? The entire 3x20 and 4x20 lines each share a single manual.
Does that mean there will be multiple frame sizes in the 2x20 line -- or that the manual is still a work in progress and the other 2x20 stats haven't been added?
   / How about...
good point! Why did I miss that?!!!
They are definately a Work In Progress... There are always revisions.
<font color="green"> Can't wait to see the pic's of this model </font>
I added them to the second post in the thread...
Here is an interesting comparison!
Does the 2520 replace the 4115 or 4210? Both!
...................2520.............4210...........4115
Engine.......3TNV82A......3TNE82A.....3TNE78A
Displ............81.16............81.16.........73.22
Gross Hp...26.5/2600......28/2600.....24/2650
PTO Hp.......20/2600.......22/2600....19.9/2650
Weight..........1865............2875..........1771
3 Point Lift....1150 lb........1700 lb.......1150 lb
3 point lift is 24" behind...
   / How about... #8
<ul type="square"> <font color="green"> </font> Does the 2520 replace the 4115 or 4210? Both! [/list]
Yes, I agree. Looks like its got the 4210's heart trapped in the 4115's body. Wheelbase, overall lenght, etc. is virtually the same as 4115. He's gonna be stout for his size! And I do like the fatter rear tires...14x17.5 compared to the 4115's 12x16.5s.
   / How about...
Now, how about the comparison to Kubotas new B series?
................Kubota B2630............Deere 2520............... Kubota B3030
Gross Hp...........26.........................26.5............................30
PTO Hp............19.5.........................20..............................23
Displ................68.5......................81.16...........................91.4
Weight.............1829......................1865............................1895
3 Point Lift........1676......................1650...........................1676
In the running....
   / How about... #10
Here's something interesting I've come across, but I might be wrong or confused. On this post it shows the 2520 having a 81.16 cu in engine...however, on the data web page it says the 2520 has a 3TNV82A engine. Now, looking at specs on the John Deere website, a 4210 has a 3TNE82A with 81.16 cu. in. The 3120 with the (same as 2520) 3TNV82A eng. number is listed with 91.5 cu. in. So does this look like the new 2520 will really have a 91.5 cu. in. engine? /forums/images/graemlins/smile.gif
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
