How about the Valve Cover Gasket
   / How about the Valve Cover Gasket #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
As my engine is only 20 hours old or so, I will need to do a valve gap check this summer. So, where do I (if it has one) get a gasket for this engine? Napa?
Also, any tricks on changing out the fuel filter on the Deutz? I think it is screw off / screw on without bleeding the system?
Thanks guys...
   / How about the Valve Cover Gasket #2
Thanks guys...
I got my gasket from a Duetz distributor--about $8 for the 45 HP version.
There is no bleeding of the fuel system necessary after changing the fuel filter. I suggest you try to put a container under it when removing it because a fair amount of fuel will spill out.
   / How about the Valve Cover Gasket #3
Thanks guys...
Somewhere along the line I determined that the early valve clearance check was not required on my 1845. I don't remember where I got that info, but there are some conflicting books. Anyone checked with Deutz?
   / How about the Valve Cover Gasket #4
Funny, I determined that too, simply by being too lazy to check the valves on a new machine:) It's going to be tougher to justify not doing the 1,000 hour check.
Sedgewood
   / How about the Valve Cover Gasket #5
According to the Duetz Operation Manual that I received when I purchased the tractor the check and adjustment as necessary for valve clearance is once at 50-150 hours and every 1000 hours thereafter.
   / How about the Valve Cover Gasket #6
Sedgewood post
05-29-2002, 12:36 PM has info as to where valve adjustments schedule originated. It was during an exchange with Charlie Iliff.:p ;) .
   / How about the Valve Cover Gasket #7
Sedgewood
Oh! Now the truth comes out. You and Charlie were just going to sit back and let me be the only dummy that didn't do the 50 hour check.
   / How about the Valve Cover Gasket #8
I think they really HAVE forgotten more than I'll ever know!:D :confused: I started reading the wisdom of these two (and many others) years ago. This forum is the ONLY reason I now have a PT. I never would have taken such a leap of faith otherwise!:p
Bill
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
2020 EZ-GO EXPRESS S4 GOLF CART (A51247)
2020 EZ-GO EXPRESS...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
