how about none of the above for a topic, AND Kioti Clutch adjustment
   / how about none of the above for a topic, AND Kioti Clutch adjustment #1
ron45
N.M.
Kioti LK3054XS
After some work on my transmission I noticed the clutch is very different. Mechanic says he did nothing to the clutch. I suppose that's possible but the clutch is fully engaged at about 1 inch of pedal travel. At 16 or 1800 on the tack that's approaching whiplash. There is about a sentence or so about free travel in the would be owners manual with a picture of some rods and linkage. Is the free travel what I want to adjust. I'm assuming that means the amount the pedal rises before the tractor moves.
How do make that distance a little more like two inches maybe?
Thanks.
Ron
   / how about none of the above for a topic, AND Kioti Clutch adjustment #2
Free travel is the other end: how much depression (from fully out) before engagement starts/ends. Your owner's manual should tell you how to adjust, or with a little inspection of the rods you should be able to figure it out. you want it to be kind of "floppy" for the first inch or so of travel. This will help keep you from riding the clutch.
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
7016 (A51691)
7016 (A51691)
Exmark Zeroturn (RUNS) (A50774)
Exmark Zeroturn...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
