How about a grease cartridge thread?
   / How about a grease cartridge thread? #1
tomplum
Elite Member
PNW
XJ2025H
I've been a Lucas Red and Tacky user for about ever. But I hate what they've done with the plastic tubes. Frankly, the grease doesn't seem the same either. What are we using for lithium spindle / chassis grease that still comes in cardboard and works well?
   / How about a grease cartridge thread? #2
Red and tacky sucks. It leeches oil and runs all over the place. This Exxon grease doesn’t do that and cost about the same as red grease. I like those plastic tubes better too. My truck toolboxes leak a little bit and those tubes don’t get ruined from being a little wet.
I've not had RNT separate. It seems thinner now though. I got 1 case from Stens after they had backordered and they came in cardboard. That was a awhile back. So as I needed it, I grabbed a pack off Amazon. Thought it was counterfeit being in different tubes. It pizzes me off that the tabs break off and then you're having to cut the ring open. The new tubes aren't filled uniformly, so 20-30% are 3" down. Their response to me is they can't get cardboard....
   / How about a grease cartridge thread? #4
I have a couple of grease guns with plungers that will just NOT fit into the grease tube. I've fought with that spring loaded monster so many times. It makes me want a 5 gallon pail and a pump to refill the lever gun.
   / How about a grease cartridge thread? #5
I hate the new plastic tubes, or at least the pull tab anyway.
The rings break off on me unless I baby them just right.
I like the old aluminum pull tabs on the carboard tubes much better.
The plastic tube is nicer, but the plastic pull rings suck. Sometimes I have to finish cutting the plastic out with a utility knife.
I can’t imagine how an old guy with arthritis would be able to yank the new plastic pull rings.
I go through ~75 tubes of grease per year, so its a problem.
   / How about a grease cartridge thread? #6
My plastic tubes still have the foil pull tab.
   / How about a grease cartridge thread? #7
Seeing as I had to practically start from 'scratch' with maintenance tools, such as a grease gun, when I retired and bought my JD tractor... I bought quite a few of those tools at the Parts/Supply department of my dealership.
The JD grease gun took JD grease tubes and I've used them ever since, always keeping one or two tubes 'on hand'.
   / How about a grease cartridge thread? #9
Why moly vs others?
The Exxon moly is only about $1 a tube premium over the regular blue grease. I feel like it works enough better to justify that.
   / How about a grease cartridge thread? #10
When it comes to grease, oil and other lubes and someone asks what is the best kind, I always want to answer “the slippery kind”. There are so many quality ones on the market you are probably good to go if you buy a well known brand name.
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
