Hourmeter FLYS on 3720
   / Hourmeter FLYS on 3720 #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
The hourmeter seems to run really fast on my 3720. With as many electronic options as it has, it would not surprise me if the hourmeter can be changed from elapsed time, to Tach-hours. Any suggestions?
   / Hourmeter FLYS on 3720 #2
Jim:
I don't think it's adjustable, but the hours aren't 'clock' hours with the ignition on like mechanical meters.
I have a 2305 that's two years older than my 3720 and it's got far fewer hours on the meter.
(Not really, the 3720 runs at a fast rate).
I've never checked the run rate but I think it goes faster when the engine is running at full RPM, etc. The one on my 2305 is just a dumb hour meter.
It probably makes more sense to track engine rotations, load, etc. but it's disturbing when you see hours go up so fast.
Anyway, your 3720 isn't weird, it's like all the 3x20 and 4x20 series with electronic hour meters.
   / Hourmeter FLYS on 3720 #3
So far the hour meter on my 3320 works correctly, I've timed it.
   / Hourmeter FLYS on 3720 #4
I had a 3320 before I traded it in on the 3720 and it had the same issue. Maybe only some have the issue. :)
JLG E300AJ ELECTRIC MANLIFT (A52705)
JLG E300AJ...
New Swict 84" Skidloader Bucket (A50775)
New Swict 84"...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
