Hour meter
   / Hour meter #1
jman1717
Does anybody know how to reset the digital hour meter on a ztr mower? I left the key in the on position for a whole week and it still started. Should have about 35 hrs. now has 159 hrs. Thanks for the replies.
   / Hour meter #2
</font><font color="blue" class="small">( Does anybody know how to reset the digital hour meter on a ztr mower? I left the key in the on position for a whole week and it still started. Should have about 35 hrs. now has 159 hrs. Thanks for the replies. )</font>
Reverse the wires to run it backward for another week. Seriously I doubt if that would work. About the only way to reset it would be to forcibly disassemble it and change the numbers.
Bob B.
   / Hour meter #3
Been there -- Done that.
You have two choices.
1.) Purchase and install a new hour meter and leave the switch on again until the desired hours are reached.
2.) Disconnect the existing hour meter. Record the hours of usage and then reconnect the hour meter when the desired hours are recorded on the meter. (This is the one I used)
   / Hour meter #4
Unfortunately there is no way to reset the digital hour meter.
In the future be sure that you remove the key when you are finished with the unit.
The hour meters are designed to record every second that power is applied(switch is turned on).
It's best to log how many hours you had previously...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
Husqvarna RZ5426 Zero-Turn Lawn Mower (A53117)
Husqvarna RZ5426...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
