hour meter
   / hour meter #1
Chuk
western PA
YM135
I bought a used YM135 and would like to install an hour meter. Does anyone have an idea on where to source the parts I'll need? I'm guessing just a cable and meter would be all. This tractor apparently never had one.
   / hour meter #3
You an always try Danny at Fredericks Equipment, if he does not have it he can steer you in the right direction.
Fredericks Importing110 Smithson Drive Hartselle, AL 35640 Phone: 256-751-3555
If you want to go used you can call
West Kentucky Tractor Parts, Inc
P.O. Box 163
6375 Joppa Landing Road
Kevil, KY 42053
Tel: (270)-462-2191 Fax: (270)-462-2485
Email: wkytractor@aol.com
Best Regards,
Bob
   / hour meter
Thanks for the replies.
   / hour meter #5
Search on ebay for "hour meter". Here is the first one I came up with. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=66991&item=7524176595&rd=1 The rectangular one will fit better into your small dash. Consider putting it on the vertical surface by your knees. It'll require a rectangular hole to mount. Drill a couple of holes with a half in bit and then finish up with a sharp square file. You wire the meter to the RUN side of the ignition switch. NOT the start. The other lead goes to ground. The tiny tachs are nice, but they don't have a replaceable battery so tracking hours with them is worthless.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
40' CONTAINER (A51248)
Genie GTH-5519 (A50123)
Genie GTH-5519...
2016 CAT TL642C (A50123)
2016 CAT TL642C...
2015 FORD E350 16FT BOX TRUCK (A53426)
2015 FORD E350...
