Hour meter stopped
   / Hour meter stopped #1
Notlaker
Bronze Member
Niagara-on-the-Lake, Ontario
Kioti CK30HST
The hour meter stopped at 2 hours on my new CK30HST even though I know I used it now for at least 6 hours.:confused:
Is there anything I can check before calling dealer?
   / Hour meter stopped #2
Your lucky it means you can sell a 10 year old tractor with 10,000 hours as new! :laughing:
   / Hour meter stopped #4
Not sure if you have fuses but if it does I would check that first. Could be a loose wire on the gauge or the feed end also.
Could just be a defective gauge too..stuff happens..
   / Hour meter stopped #5
Is your tach still working?
If yes see dealer - something unplugged or dash cluster failed.
If no - go to right side of tractor below injection pump, see if plug is unplugged. Remove plug reinstall. Sensor is screwed in engine - missing? Take to dealer.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
New Long Forks (A53002)
New Long Forks...
