Hour Meter-How Does It Calculate?
   / Hour Meter-How Does It Calculate? #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
On the newer digital hour meters do they just show the actual time a engine is running or do they also take into consideration the engine rpm's and what gear you are in while working? Mowing for a hour in third gear is different than plowing in first gear at high rpm's, isn't it as far as wear and tear?
   / Hour Meter-How Does It Calculate? #2
The hour meter just shows hours engine has run but doesn't consider what tractor is doing.
   / Hour Meter-How Does It Calculate? #3
Usually [ usually ], if the hour meter runs just off the 12 volts, it is a straight time period. If the hour meter gets it's input off the alternator, it USUALLY means the time is dependant on the RPM. Idle is not weighted as much as @PTO RPM. My Mahindra 5035 gets its input off the alternator.
   / Hour Meter-How Does It Calculate? #4
Tractor hour meters (everyone I have ever seen) are tied to RPM and are usually set to calculate hours at PTO speed. Simple hour meters like on lawnmowers start when you turn the key. Some will even run for several minutes after the key is turned off. I think the one on my Ferris mower is that way. First use was .6 hours. I cranked it up a couple of times to move it around in my shop and next thing I look and it has 1.0 hours and at most it ran 5 minutes total. I know when I took my flying license, the Hobbs meter which is what they used to charge time (not the RPM hour meter) ran 6 minutes each time you turned on the key.
   / Hour Meter-How Does It Calculate? #5
[QUOTE the Hobbs meter which is what they used to charge time (not the RPM hour meter) ran 6 minutes each time you turned on the key.[/QUOTE]
Sounds a lot like my hydro meter!!
   / Hour Meter-How Does It Calculate? #6
Hydro meter = electric meter
Looney = Canadian Dollar
Tooney = two of them there dollars
boot = about
For all of you that don't live next to Canada.... [ :) ]
2008 CAT 287C (A50854)
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
1996 Mack RD688S Cab and Chassis (A50860)
1996 Mack RD688S...
2011 FORD F-450 (A50854)
2011 FORD F-450...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
