Hour meter adjustment
   / Hour meter adjustment #1
westbrooklawn
Platinum Member
North Carolina
kubota L3400HST
I somehow left the ignition switch on my Kubota RTV900 in the on position... 51 hours later the battery went dead.... I know it was 51 hours because that is how many hours my hour meter racked up! I would have thought the motor would have to be running to record hours, but apparently if the the switch is in the on postion the meter runs. My question is how do I get the meter adjusted to reflect the true running hours... it reads 121 now, but I know it should only be 70.
Is there anyway to put DC on the meter to run it backwards (reversing the + and - leads)? I could always disconnect the meter for a period of time, but 51 actual run hours would be several months of use. Any suggestions?
   / Hour meter adjustment #2
I think you stuck with it like that...just record the hours in you service record as a oops.
   / Hour meter adjustment #3
Or, swap the hour meter out, run up to 51 hours on the new one, and then switch back to the one with the "extra" hours on it...
rus geek... that may be the answer... but a rather expensive solution.
   / Hour meter adjustment #5
I did the same thing the other day but it was for only about 10 minutes.
Now I take the key out and put in on the seat or in the cup holder, second key in the garage just in case I loose it.
How about this:
Tachometer and Hour Meter Combination
Use it until you are caught up, You can put on something else afterward.
   / Hour meter adjustment #6
How about this:
Won't work on a diesel.
   / Hour meter adjustment #7
How about just disconnecting the hour meter for 51 hours?
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2014 JCB 930 6,000LB 4x4 Rough Terrain Straight Mast Forklift (A49346)
2014 JCB 930...
2020 Chevrolet Express 2500 Animal Control Cargo Van (A48081)
2020 Chevrolet...
2025 Swict 72in Bucket Skid Steer Attachment (A49346)
2025 Swict 72in...
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
2018 Dodge Journey SE SUV (A50860)
2018 Dodge Journey...
