drssg
Veteran Member
I have a 10 gallon electric hot water heater in my barn that is about 15 years old, and I recently noticed some hot water dribbling out of the pressure relief valve. My wife had recently washed her horse, and she said she used all the hot water in the process. I currently have the water and electric turned off to the heater, so I don't know whether the leaking would have been temporary.
So I have two questions that come to mind. First, could this be considered normal? The tank went from 10 gallons of cold water to 10 gallons of hot water, and I could see where that would cause expansion and some of the hot water would leak out.
Second, I noticed that there is no tube attached to the pressure relief valve, so the water was leaking onto the plywood that is supporting the water heater on its shelf. At a minimum, I would like to divert that water, so it doesn't eventually rot out the wood.
I would be OK with a small amount of water being diverted straight down to the side of the plywood. It would fall on the lid of a sump in that corner. There is also a sink near the corner.
I would appreciate advice on whether the leakage is normal, how best to divert any leakage, and anything else I am missing. I'm definitely not a plumber, and I'm open to calling one, but I also like to fix things myself when I can.
