hot water bottle
   / hot water bottle #1
deereman64
I posted about a month ago a problem that I had of my Deere stalling as I engaged the drive. The suggestion was that the safety switches under the seat were freezing up. Well, it happened again tonight so what to do? Somehow, I had to get heat onto the switches. the solution was to wrap a hot water bottle in a towel and leave on top of the switch. Worked like a dream and she moved first time. Meanwhile, the wife thought I had totally lost it.
   / hot water bottle #2
It may be possible to put in a very small heater fan to keep the switch warm so it wont freeze up. hope this helps
   / hot water bottle #3
Would pouring a little alcohol or spraying with an electrical cleaner help get rid of the moisture that is causing the problem?:D
Land Pride 55 10' 3pt. Hydraulic Blade (A50775)
Land Pride 55 10'...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
UNUSED WOLVERINE PFF2-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2017 Ford F-250 Crew Cab Pickup Truck (A55788)
2017 Ford F-250...
2011 GMC Acadia SLE SUV (A55758)
2011 GMC Acadia...
2006 Isuzu NPR-HD Landscape Dump Truck (A55788)
2006 Isuzu NPR-HD...
