Hot Stuff !!
   / Hot Stuff !! #1
Uncle Levi
Bronze Member
Maxbass, north Dakota
John Deere 2020
My JD 2020 overheats after about 20 minutes running. I've replaced the water pump, radiator and thermostat and the fan belt is tight. Could the problem be the water jacket needing flushed out ? I'd really appreciate any advice. Mike
   / Hot Stuff !! #2
Try running it without the thermostat.
Remove the radiator cap and make sure the water is moving through the hoses.
Is the gauge accurate?
Eddie
   / Hot Stuff !! #3
I have never heard of the engine ports getting stopped up, but I suppose it is possible if one fills the radiator with muddy water like the Japanese rice farmers do. Nothing saying that the new thermostat is not faulty. I would follow Eddie's advice and remove it for testing. You should be able to see the water flowing into the radiator by viewing from the removed cap. If it is flowing thru which it should be as all is new, then I would suspect a faulty gauge if the thermostat is working properly.
There is nothing else left that would make it run hot with all new cooling system.
   / Hot Stuff !!
Thanks Gary and Eddie. It MAY be a bad thermostat I guess. I think the gauge is right, because when I shut it off it DEFINATELY is HOT ! If you think of anything else, please let me know. I'm out of ideas. I'll take out the thermostat and see what I get.
   / Hot Stuff !! #5
How positive are you that the thermostat is facing the right direction?
Eddie
   / Hot Stuff !!
Eddie
I wondered about that too, Eddie. I took it (the thermostat) out this afternoon, so when I mow with it this weekend I should know. The answer to your question is: not sure.
   / Hot Stuff !! #7
When my 2030 started running hotter than normal (normal is temp needle just right of straight up) I used compressed air to blow the dirt from the radiator fins. That fixed mine.
2019 John Deere 3025E (A50123)
2019 John Deere...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2007 GMC Sierra (A50123)
2007 GMC Sierra...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
