TBone
Platinum Member
I have a Kubota M4900 that I bought almost a year ago. I really like the tractor. It does everything I ask and has been trouble free.
There is one thing, however, that worries me. The rear end (around the pto shaft) gets REAL HOT - hot enough that your can't hold your hand on it for more than a second or two. I assume that the heat is coming from hot hydraulic/transmission oil that is being circulated in there. When I noticed it I had been using the pto (rotary cutter) and also had been using the lift quite a bit.
I asked the dealer about it and he said that the oil can run about 100 degrees higher than the ambient temperature, which is close to 100 degrees in the summertime. 200 degrees fahrenheit is pretty hot. I have never noticed any of my others running this hot.
Everything works fine and there are no unusual noises. Do I have a problem? (The tractor does not have hst or a fel)
TBone
TBone
