I disagree. The hot air furnace can only get as much energy out of wood as a wood stove. Same efficiency. Actually, the standard wood furnace is not even EPA certified and allowed to be a very inefficient device but lets just assume that they are equal. Then you must consider heat delivery. The stove in a room delivers all of the heat to the room, that's right, 100%. The wood furnace suffers from a thing called duct loss. Meaning that while moving that air through the ducts to the rooms it is loosing heat to the surroundings. Duct losses usually account for 15-30% of the energy. Also consider the electrical demands of that wood furnace like blowers and controls.
While it may be true that a wood furnace is more efficient than a wood boiler, I don't know, it is not true that a wood furnace is more efficient than a woodstove. Not even close.
Efficiency is one thing. Capability and comfort is another. While consuming massive quantities of wood, the wood furnace will do a superior job of distributing the heat to the entire house. Anyone trying to heat a house from a woodstove in the basement will be well served by a wood furnace. Woodstoves are area heaters.
