HOSES IN JEOPARDY
   / HOSES IN JEOPARDY #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I recently had a WR Long 3rd function switch added to NH TC40DA for grapple use. Works the nuts. Love it. Question is how to protect the hoses that run from the electrohydraulic valve at the rear of the tractor, near the hydraulic reservoir, to the FEL and then to grapple. The hoses loop downward as they exit the valve before coursing forward to the FEL. Can't really tie they up much better using cable ties without kinking hoses. I guess 2 right angle fittings could help. Does anyone use metal "hose" for such a run??
   / HOSES IN JEOPARDY #2
I like to zip tie my hoses at a comfortable amount of bend, and then if they are in places where they will get abraided.. then u run them thru something.. either some kind of loom.. or well.. in hard times.. thru old fire hose...
Soundguy
   / HOSES IN JEOPARDY #3
I just saw a NH TN-series tractor (75 HP, I think) set up for logging and other work in the woods. One of his concerns was the hydraulic hoses he had added for his grapple. He ended up changing the standard hoses for metal ones. He was able to route these more preceisely than the rubber ones which were on there originally, so they were well protected. Of course, he ended up going whole-hog and had a substantial belly pan added to protect the entire underside.
If you find someone who has "hardened" a tractor for logging use, they'll have some good ideas. There aren't many applications tougher on the underside and exposed hydraulics on a tractor.
John Mc
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
Light Tower (A52377)
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2017 International Distributor Truck (A52377)
2017 International...
2022 BOBCAT S64 COMPACT SKID STEER LOADER (A53473)
2022 BOBCAT S64...
