Hose size question
   / Hose size question #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
All the hoses on my Yanmar YM2310 for the FEL are 1/4" according to the markings on the hose. When I add the power steering cylinder I would rather use 3/8" hose. The only reason being that there will be less resistance to flow. The 3/8" hose is virtually the same price as the 1/4" stuff as are the re-usable fittings. Are there any reasons to NOT use 3/8" hose when everything else is 1/4"?
Thanks,
Eric
   / Hose size question #2
Shouldn't be a problem at all! flow will be increased, but also restricted by any existing fittings.
Yeah, that's what I think too. The fittings will be the main restriction.
Cheers,
Eric
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
2000 Ford F-650 TMA Attenuator Truck (A50323)
2000 Ford F-650...
Root Grapple (A50322)
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
