hose hookup on John Deere 670... help!
   / hose hookup on John Deere 670... help! #1
dupuy
I have just bought a small PowerHorse log splitter to use with my 670. However, I can not find any way to identify which two of the four hydraulic connectors to connect the hoses to.
There are four connectors just forward of the driver's left foot, numbered 1,2,3,4 in a clockwise direction. The lever for the FEL is by the driver's seat, and I understand that two of the connectors will respond to moving lever front/rear and two connectors respond to moving lever side to side... but which ones? And which is source and which is return? I don't have a front end loader, and the hydraulic connectors are not identified in the 670 manual.
I hope someone can help! thanks, David
   / hose hookup on John Deere 670... help! #2
Welcome to TBN:D
1 and 2 should be the UP/DOWN , or for/aft joystick movement
3 and 3 should be the DUMP/CURL, or the left/right joystick movement
The IN and OUT changes depending on which way you move the joystick.
thanks kenny... I appreciate your help. I will hook it up and try it out! This looks like a very useful forum for tractors, glad I found it. best, David
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
Target Econline 2 Concrete Saw (A49461)
Target Econline 2...
7021 (A50322)
7021 (A50322)
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
