Hose burst on tractor loader, do I need to bleed?
   / Hose burst on tractor loader, do I need to bleed? #1
billybonds
Bronze Member
Medford
New Holland Workmaster 35
I just had a hydraulic hose burst on the loader for my New Holland Workmaster 35. I'm going to run out a pick up a replacement hose which is easy enough. Will I need to bleed the system after replacement? I cant find anything saying I need to bleed it.
   / Hose burst on tractor loader, do I need to bleed? #2
Just put the new hose back in. Cycle the loader function affected by that hose a couple times and you're good to go.
   / Hose burst on tractor loader, do I need to bleed? #3
Take the old hose with you for replacement. Generally don’t need to bleed the air will work out in a few cycles. Check fluid level after.
   / Hose burst on tractor loader, do I need to bleed? #4
Yup once hose replace exercise loader couple times than check fluid.
   / Hose burst on tractor loader, do I need to bleed? #5
No cycle the loader a few times and then check the fluid level when you’re done.
   / Hose burst on tractor loader, do I need to bleed? #6
The only "Bleeding" is the cost of refilling the oil.
   / Hose burst on tractor loader, do I need to bleed? #7
Run the loader through the full range and "dead head" it for a couple seconds on each end of the travel.
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2023 Kubota KX71-3S Mini Excavator (A52377)
2023 Kubota...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
