Horsepower and cu. in. ?
   / Horsepower and cu. in. ? #1
Dave-J
National City CA
What do Manufacturers do to get more HP out of the same size engine? JD uses a 179 cu in block from 42-74 HP in the 5003 series and Kubota uses the same size block for the M6040-M7040
Dave
   / Horsepower and cu. in. ? #2
More fuel and turbo charging are 2 ways.
   / Horsepower and cu. in. ? #3
Many ways:
more fuel
more air, cooler air
camshaft type
altering bore and stroke
compression ratio
Piston design
combustion cylinder design
changing allowable rpm
changing the materials rotating and moving parts are made of
flywheel weight
And so many more I'm not aware off
   / Horsepower and cu. in. ? #4
It doesn't take much to upgrade hp in a stock diesel engine. My old dodge 6-cyl diesel went from 250 hp to over 400 hp with just larger injectors, larger fuel pump, and a remapped ECU. I highly doubt they do any major internal changes, they can get away with just more fuel and air. Also by using the same block, pistons, crank, etc... they can increase productivity on the line.
   / Horsepower and cu. in. ? #5
Dave
In MOST cases, they START with the high end of the spectrum, and lower (de-tune) HP outputs to achieve lower ratings.
Less fuel/air. In some cases, smaller injectors/injector pumps/cam/compression.
Over the years, Massey Ferguson used the AD152-3 Perkins 3-cylinder on various models of tractors. It came with HP ratings from 35 to 57. All that was done was raise RPM's and fuel screw settings on injector pump along with air intake capabilities.
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2011 DOOSAN G25 GENERATOR (A52472)
2011 DOOSAN G25...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
